No mobile signal since yesterday
FIXED- Subscribe to RSS Feed
- Mobile
- No mobile signal since yesterday
13-05-2023 10:10 AM
EE status checker doesn't show anything amiss.
I've tried my SIM in another device, still no signal.
I tweeted Plusnet yesterday afternoon and still haven't had a response.
I lost signal just after installing the latest Android security update, could it have fried my SIM?
Fixed! Go to the fix.
Re: No mobile signal since yesterday
13-05-2023 10:13 AM
I've been in touch with Google pixel support and run through all their suggestions.
It's definitely my SIM/account that's the problem, not the phone.
13-05-2023 10:31 AM
Have you tried:
Go into the phone's settings, network and internet, SIM settings there is an option to Automatically select network which is usually set to On. If I click on that I can manually force the phone to select plusnet - several networks are shown and they all state that they are forbidden even the plusnet connection. I then put the connection back to Automatic.
It worked on my Pixel 6a when I lost connection - frustrating when it happened and that I needed to keep doing it. So frustrating that I've now moved from plusnet to Smarty where I now have WiFi calling and can connect to 5G.
13-05-2023 10:35 AM
13-05-2023 10:38 AM
13-05-2023 10:39 AM
I'm really pleased to have helped. Plusnet could never offer any help and once I discovered that this worked at least I knew that I had a workaround whenever I lost connection.
- Mobile
