No mobile data or call this morning
grocery
Network down as far as I can tell, and can't call customer service because no wifi calling.
Anyone else lost connectivity?
7 REPLIES 7
Fixes: 407
Re: No mobile data or call this morning
Have you checked the EE status checker https://coverage.ee.co.uk/coverage/ee to see if there's a network problem in your area ?
grocery
Yes
Fixes: 407
Its not a general problem, I've just tried my phone and it works fine. Im currently in the South West.
grocery
So how do I get help?
Have tried my sim in an old handset - no data or calls
Have moved 10 miles - no data or calls
Can't call plusnet because... no data or calls
I tweeted an hour ago with no response
grocery
minor update: I can call 999, so thats good
James30
Fixes: 26
@grocery -  I'll DM you so you can send me your postcode and I'll check the system for outages.
James - Plusnet Sheffield
dltool
I'm having the same problem - no signal for hours. My partner is also on plusnet mobile and does have signal. Tried my sim in another phone and no joy. I tweeted 4 hours ago (can't phone as no signal) and haven't had a response. The EE service checker shows no problems in my area.
