No data
- Mobile
- No data
No data
29-09-2017 7:18 PM
I bought a sim only deal and inserted sim to my phone. Texts and calls are fine but it seems data is not working now.
Message 1 of 2
(360 Views)
1 REPLY 1
Re: No data
29-09-2017 8:21 PM
Sorry to hear this, hohoyaa. Don't panic, though: the fix should be relatively easy
You'll need to perform a 'network settings reset' on your handset. You will be able to find instructions online by typing 'network settings reset' followed by the make and model of your handset into a search engine, but if you'd like me to guide you through it please let me know which handset you have.
Message 2 of 2
(347 Views)
