No Network
MalcolmH61
No Network
Hi I got problems got no Network coverage been on the phone to Plusnet I sometimes manage a couple of minutes before the call is cut off I did manage to speak to an advisor earlier before losing signal and he said there's problems with three masts in my area can anyone suggest what I do I think my partner has been trying to contact me all morning I hope its non urgent, so how do I find out the current situation and I it's going to get fixed
1 REPLY 1
willcutforth
Fixes: 97
Re: No Network
Hey there @MalcolmH61 sorry it's taken so long to get through to you, we're super busy at the moment.
So sorry to hear about the mast issues, if you can send me over your username via PM that would be great. You will need to post 5 times before you can do that though.
 Will Cutforth
