No Data Connection.
FIXED- Subscribe to RSS Feed
- Mobile
- No Data Connection.
Re: No Data Connection.
19-09-2018 8:43 PM
Similarly - only resolved by leaving Plusnet and moving to Virgin. Immediately started working again with a 30 second process to load the APN settings.
04-10-2018 11:07 PM
07-10-2018 10:07 AM
Same here in Portugal! No data connection since we arrived last Sunday yet my wife’s o2 sim works fine in my phone.
I’ve tried all the ‘fixes’ but nothing changes.
I can’t access the apn as the carrier setting just takes me to EE.
So frustrating as it worked fine in Spain last month!
I think it’s plusnet who are having problems with some networks but they won’t admit it will they?
31-10-2018 1:49 AM
05-11-2018 7:53 PM
Hi All, I am still having the problem with no data. Using a Harrier from EE. Problems started when I got back from Holland. Tried new sim, taking it out Apn etc. No luck.
06-11-2018 12:11 PM
Hi @BobinLondon, can you PM with your account details so I can look further into this for you.
06-11-2018 5:14 PM
Don’t bother! They promised me an answer weeks ago and I’m still waiting!
11-11-2018 11:46 AM
I am also having the problem of no internet. The steps I have tried so far include:
- adding the recommended APN settings,
- using a new SIM sent to me by Plusnet,
- taking the SIM out for 5 minutes and then re-inserting,
- getting Plusnet to disable and then re-enable data,
- restoring my handset to factory settings.
I have had 2 long sessions with Plusnet's Technical Support but they have been unable to fix the problem. I have also tried a different SIM in my handset (which works fine) and my SIM in a different handset (also works fine). I have no idea what else to try to fix this issue. Can someone from Plusnet's Technical Support please help?
11-11-2018 1:58 PM
Good luck with that. I’ve been waiting since 5th Oct for an answer from their technical support. Waste of space.
11-11-2018 9:28 PM
Hello @yellowmoon, I am sorry to read about these issues and apologies for the frustration caused. Its great that you've tried these troubleshooting steps out already, could you PM me with your full address with postcode, full name, mobile sim number.
15-11-2018 3:36 PM
Hi @Mads,
I sent you a couple of Private Messages at the beginning of the week about your suggestion of forcing 3G or 4G mode on my phone. I haven't heard back, are you still looking into this problem? Or can anyone else from Plusnet Tech Support help me, as I've been struggling with this for some weeks now, and it doesn't honestly feel like I'm getting much further forward.
Kind regards
15-11-2018 3:43 PM
+ one. It is getting really boring not hearing any solution or that it can't be solved. But other people seem to have got their problems solved. Is Michael Williams not there any more?
16-11-2018 9:36 AM
Hello @yellowmoon, I am sorry for the delay. I have just replied back via PM.
@BobinLondon, I would suggest calling into our support teams as they will be able to advise further on the operations side of things.
No data connection
17-11-2018 1:35 AM
Today I have lost data completely on my android phone, deleted and recreated the APN, reset the phone, tried the sim in a 4g tablet and nothing... Could not have happened at worse time as I am going away for the weekend.
Reading through the forums there are a few horror stories so time to migrate my mobile it would seem
Re: No data connection
17-11-2018 2:37 PM
Same here lost data connection since yesterday
Double checked with other sim card the phone is ok. Plusnet said will send a new sim card replacement in 2 working days time but I'm not sure if that will solve the issue. Very frustrated
