I need a duplicate SIM
FIXED- Subscribe to RSS Feed
- Mobile
- I need a duplicate SIM
16-05-2020 11:11 AM
I have bought a phone to leave in the car, and need a duplicate SIM so that I don't have a second account.
Is this possible, and if so, how do I go about getting one?
I have searched the help pages but to no avail.
Fixed! Go to the fix.
Re: I need a duplicate SIM
16-05-2020 11:18 AM
If only that was possible it would save some of us a small fortune!
16-05-2020 11:24 AM - edited 16-05-2020 11:27 AM
deleted
16-05-2020 11:30 AM
If you mean two phones from the same account with identical Sims I am sure you can't do that
If it's for emergency use in the car you are better having a Pay As You Go with credit that does not run out after a time period the Three 321 is very good that's what I use as a back up
Credit can be purchased from Three shops or local convenience shops when needed
16-05-2020 11:39 AM
I believe most mobile networks have a 3-6 month usage period before the sim maybe disconnected.
CJT
16-05-2020 11:45 AM
I was aware that you need to make a 'keep alive' call from time to time.
Easy to remember to do when you do a battery check.
16-05-2020 11:46 AM - edited 16-05-2020 11:51 AM
Thanks HelloDuck. I thought such accounts existed, but I was having trouble finding one.
ETA: Either Three have discontinued this option, or they have it very well hidden!
16-05-2020 11:53 AM
Yes the credit does not expire but the phone has to be used every six months I have a reminder on my main phone to remind me
As you can see below I still have £9.24 from the £10 credit I put on the account
Credit | Valid until | Remaining |
Top-up credit | Won't expire | £9.24 |
Total Credit | £9.24 |
Your credit will not expire
This information was correct at 11:44 on 16th May 2020
16-05-2020 11:56 AM
09-11-2020 11:52 AM
It's probably coming - T mobile do a thing called paired digits in America:
https://www.t-mobile.com/support/plans-features/get-started-with-data-with-paired-digits
