How to change plan
- Mobile
- How to change plan
How to change plan
21-04-2017 10:51 AM
Hi
Can you let me know how to switch plans? I see there is a new plan which gives 1Gb, 500 mins, 500 text for £5 which I would like to change to.
thanks
rk508
Re: How to change plan
21-04-2017 12:01 PM
Hi I cannot see a plan for 1Gb 500 mins 500 texts for £5.00 there is one for 1GB 500 mins 1000 texts for £5.00 which is better.
If you are already with PlusNet just ring 500 from that mobile its free or 0800 079 1133 from a landline.
I've just increased my plan its very easy to do only took a few minutes.
Hope that helps.
21-04-2017 12:18 PM
@rk508 If you've not already done it then I've just used live chat to change down to the same package, unlike Sky's equivalent it's really quick.
21-04-2017 2:34 PM
Hi @rk508,
I'm glad to hear you're liking the look of our new plan! It's a great choice to go for. You can change your package by dialing 500 from your Plusnet SIM, or you can contact our friendly Live-Chat Team via our website https://www.plus.net/mobile/. Alternatively, I'll be more than happy to ensure this is sorted for you; so you can click on my profile and send me a private message.
It's a really simple process, we'll change the package and it will take effect on your next bundle refresh date. -Ashleigh
