Error 0
Isembard
Error 0
Hi
I get a message "Can't send message with Plusnet - error 0" when Itry to repond to a messagefrom my medical centre. The mesage says it is free to text an is registered with the Regulator.
Any clue about this message?
3 REPLIES 3
Mustrum
Fixes: 76
Re: Error 0
Presumably it is a short code, which PN do not support.
Is there a long number to reply to?
Isembard
Re: Error 0
I reply to myself.
Just discovered that Plusnet doesn't support responding to short codes - which the message from my medical centre is.
So it's goodbye Plusnet, Hello another mobile service!
Isembard
Re: Error 0
No there isn't, unfortunately.
Thanks for the help.
