Which mesh system would suit me?
Longliner
All Star
Fixes: 8
Please could I ask the community for advice on buying a mesh system? At present we have TP-Link powerline extenders which have been excellent over the past few years, so I chose Deco M4 as a replacement for all-over coverage using Hub Two in bridge mode. This was great until switched off, when the mesh required complete re-install as it doesn't seem able to hold login details. It had been easy to set up out of the box, but reboot was impossible as first one unit showed red light, then another. Gave up in disgust and returned it.
I'd try BT Mesh but this does not suit the Hub Two. We stream TV and lnewspapers from our 80/20 connection, no gaming etc so our requirement is simple -- as long as the thing reconnects when power is restored.
