EE coverage Vs Plusnet
seasidebob
Hi - is it still the case Plusnet coverage is not the same as EE? These earlier posts suggest Plusnet do not have access to 800mhz network
https://community.plus.net/t5/Mobile/Plusnet-Mobile-reception-not-as-good-as-EE/td-p/1587172
https://community.plus.net/t5/Mobile/Do-Plusnet-customers-get-full-EE-coverage/td-p/1533809
2 REPLIES 2
Fixes: 365
Re: EE coverage Vs Plusnet
@seasidebob
Yes.
To justify the budget price tag. Plusnet only offer a subset of the full EE offering.
Hence the restricted number of bands, no short code calling etc.
I fear that you only get what you pay for.
Smith7
Seasoned Pro
To put this straight I was with Life mobile only on 3G then was transferred to PN when they took over so it's a few years and was then onto 4G
I have a good signal on EE/PN  where I live and mostly where I go and use my phone as a hotspot at the caravan with no problems  PN let you tether and at 30GB U/L Mins U/L Texts for £10 it's a bargain
You cannot use certain things but short texts are something I personally would never use because of the costs for some codes and repeat charges for others
It's a suck it and see and only a 30day contract its well worth a try for little cost
I also have a Three sim  back up phone and the signal is not as good as PN but have it in case the  EE goes down
