Deafault SIM PIN
JamesMichell
Deafault SIM PIN
Does anyone know the default PIN for the Plusnet SIMs?
RebekaPreston
All Star
Fixes: 31
Re: Deafault SIM PIN
Hi JamesMichell,
The default SIM pin's are as follows:
0000
1111
1234
If you are looking for a PUK code, you will need to contact us for this as it is account specific.
- Rebeka Smiley
 Rebeka Preston
Grainfoot
How do I know which one? Tried 0000 didn't work only have two more attempts.
RebekaPreston
All Star
Fixes: 31
Hi Grainfoot,
What message are you receiving exactly on the screen?
- Rebeka Smiley
 Rebeka Preston
Grainfoot
Thank you tried one of the other nos and it worked.
RebekaPreston
All Star
Fixes: 31
You're welcome Grainfoot, anytime!
- Rebeka Smiley
 Rebeka Preston
JamesMichell
So the default PIN for setting up security on your voicemail is 0000.
So to set up a lock on your SIM with a PIN the default is either 1234 or 1111.
Can you tell me which one it is, please? I have only one chance left having tried 9999 and 0000.
RebekaPreston
All Star
Fixes: 31
Hi JamesMichell,
Can you please clarify if it is a SIM pin, PUK code or a password you are trying to set up on your handset itself? Are you receiving an error message? If so, what does it say?
- Rebeka Smiley
 Rebeka Preston
Grainfoot
For me the Deafault pin for the sim was 1111. Hope it works!
JamesMichell
I want to set security for the SIM. That means if someone puts my SIM in another phone they will be asked for a PIN before they can use the SIM. However to set this up I need to know the default PIN on Plusnet SIM. Without that you can't set a new one.
So under IOS you go to Settings/Phone/SIM PIN and then activate SIM PIN, at which point it asks for your PIN, which in this case is the default one set by Plusnet.
So this is the one I'm trying to find out - the SIM PIN
JamesMichell
Oh great! Thanks Grainfoot - most helpful.
RebekaPreston
All Star
Fixes: 31
Hi JamesMichell,
The following are the default SIM pin's.
  • 0000
  • 1111
  • 1234
I understand you have already tried one of these, but I'm unable to tell you exactly which one will work as it all depends on the handset itself.
- Rebeka Smiley
 Rebeka Preston
JamesMichell
A SIM PIN applies to the SIM not the handset, so thanks for your reply but I think we now have the correct answer from Grainfoot
RebekaPreston
All Star
Fixes: 31
Just to clarify JamesMichell that there are 3 different sim pins, we can't advise exactly which one will work, as all 3 work in different handsets.
For example, 0000 could work in a Samsung but not an iPhone and vice versa even though they both have a Plusnet SIM card.
Your correct in saying that a SIM pin is related to the SIM but this was my explanation with regards to the comment 'depending on the handset'
- Rebeka Smiley
 Rebeka Preston
JamesMichell
I have absolutely no gripe with you; you are presumably being fed inaccurate answers by your IT support, and after all, thanks to to Grainfoot I do have the correct answer.
But the fact is that over the coming months many people will search for or Google the same question and I think it's important that the correct answer is available to them - and not your half correct answer.
The SIM lock PIN is applicable only to that SIM irrespective of the the handset, or who makes it. So Plusnet need to make sure they understand that and have the correct answer to hand when their customers ask for it.
If you still do not understand or accept what I am talking about then see here: http://ee.co.uk/help/safety-and-security/security/activate-a-pin-for-your-sim
or here: http://vodafone.intelliresponse.com/index.jsp?id=1461&question=How+to+find+and+reset+the+PIN+code+on...
or here: https://support.apple.com/en-gb/HT201529
but for Plusnet as at 6th December 2016 the correct answer to the question: "what is the default SIM PIN for PlusNet Sim cards" is 1111.
OK?
