Damaged Sim Card
Al85
Damaged Sim Card
I have somehow damaged my sim card when I put it in my new phone. It works but not very well, phone calls not connecting properly. How do I order a replacement with the same number etc? Many Thanks
Fixes: 30
Re: Damaged Sim Card
Hi Al85,
Thanks for getting in touch with us!
So we can determine if this is a SIM or handset issue, can you please try the SIM in another handset and perform a test call?
- Rebeka
 Rebeka Preston
Al85
I have swapped sim cards with a friend and they were able to make and receive a call but mine cut out when I made a call and it rang once but didnt let me pick up the call
Fixes: 5
Thanks for giving this a try Al85!
If you could please send me a PM we will be able to whizz through some security and look into getting that new SIM ordered Smiley
-Liv
 Liv Robinson
Flawless
My phone is saying 'insert sim' upon checking it, it appears to be damaged. Can I order a replacement sim please?
Fixes: 15
Of course you can - simply send me a PM with your mobile number to get started Smiley
 Michael Williams
