Clone sims
FIXED- Subscribe to RSS Feed
- Mobile
- Clone sims
07-08-2020 11:24 PM
Fixed! Go to the fix.
Re: Clone sims
08-08-2020 3:23 AM
In a word, @Lwio - No. The only way to do this would be to swap over the SIM.
08-08-2020 3:35 AM
Not easy and legally.
The SIM has a Ki number in it, which is only known by the physical network and your network operator. When it logs on the network it does a challenge (not sure what that entails but I assume it is some kind of the encypted one), I assume it is unique to every SIM.
Also how does your network operator find you when someone wants to make or receive a call? I believe the local mobile masts keep an eye on your IMSI, maybe your IMEI too and probably leave a record of where you are when you move around. Also when you go roaming, I believe the home network actually keeps a record of how to reach you, so you're +44 number gets routed to you.
So even if Ki has been cracked by now (I am not sure if that is the case, I haven't looked it up).
I think you'll get to get used to two devices with two SIM's and it is not too hard to set up to set up call diverts between the two so they apeear mirroried.
Re: Clone sims
08-08-2020 8:08 AM
Re: Clone sims
08-08-2020 1:15 PM
Never tried diverts, but say when phone A is on charge I believe there is a "Unconditional Divert" to enable for calls to number A to be forwarded to number B.
Once you enable it, so when on charge, then calls to A should go to B instead.
Vice versa and all that, so in the other case swap A and B around in what I've just said 🙂
Once you get it set up (not too hard), it should just be a case of enabling the divert before you switch it off and disabling it when you switch it on. Depending on the device you're using it should just be a case of making a few key presses. Little bit of hassle, but nothing too major once you get used to it.
Again - I have never tried diverts really. So take what I say with a pinch of salt and all that.
Re: Clone sims
08-08-2020 3:49 PM
Forgot to mention when one is charging then you need to switch it off, otherwise it will still be working and ring on charge.
