Account Password
fwo778
Account Password
When clicking on the link for the password on the Welcome message from Plusnet I keep getting the URL has expired this has happened twice after customer service sent a new Welcome message each time was wondering if anyone has been experiencing the same problem
11 REPLIES 11
HarryB
Fixes: 256
Re: Account Password
Welcome to the community forums @fwo778
I'm not sure what link you're referring to in the Welcome email. Is this regarding a mobile order?
 Harry Beesley
fwo778
The link to set up a password so I can see my account
HarryB
Fixes: 256
A password for a home phone and broadband account would be set during the signup process.
As per my previous response, please could you confirm if this is regarding a mobile sim order?
Thanks.
 Harry Beesley
fwo778
Yes it's a mobile sim account
Hi @fwo778
Thanks for getting in touch. The URL will expire within 24 hours after the initial Welcome Email has been sent.
If you'd like to drop me a PM with your account details, I can generate a new password for you; which again you'll receive via e-mail. Once you've logged in with the randomly generated password, you'll be able to change it to something more suitable for yourself.
Apologies for any inconvenience caused, but I'll ensure this is sorted for you. -Ashleigh
JeffL
Hi Ashleigh,
I'm having a similar problem except my link to get a My Account password hasn't expired, rather it simply points to http://google.com for some reason so doesn't work.
Can't figure how to PM you since you're shown as anonymous but if you could kindly please do the same for me that would be great
Kind regards
SeanCorri
Hi JeffL!
Thanks for getting in touch! Unfortunately, Ashleigh has since moved on, however, I will be more than happy to pick this up if you would like to drop me a PM. I'll be able to generate a fresh password reset link for you which should direct you to the correct page.
I'm sorry for the inconvenience, however, rest assured I will help you out! -Sean Smiley
JeffL
PM sent thanks
SeanCorri
Hi JeffL!
I'll pick this up now! -Sean Smiley
scrumpydude
Similar problem for me. Didn't realise / notice the link was only valid for 24 hours.
Sean, could you PM me as don't seem able to PM you.
SeanCorri
Hi scrumpydude!
I'm sorry to hear that! Our password reset links only remain valid for 24 hours for security reasons. We want to protect your account as much as possible, and placing a validity timer on password reset links is one method that we use to acheive this.
In order to send PMs, you'll have to verify your email and then post a public comment on a thread. You should then be able to get in touch with me!
I can see that you have sent me a PM scrumpydude, and i'll be sure to follow this up for you! -Sean Smiley
