Windows Vista as a Gateway
- Trials
- IPv6 Trial
- Re: Windows Vista as a Gateway
18-12-2013 9:05 PM
I'm wondering if anyone else is unlucky enough to be running a Windows Vista PC/laptop on their IPv6 enabled LAN?
One of the most frustrating issues I had getting v6 working was one of the laptops in the house deciding to advertise itself as a default gateway. With it only being on intermittently it took me a good few days to track the little bugger down. I didn't get round to doing much investigation into it, just turned off its IPv6 stack and crossed my fingers it will go in the bin before it really needs native v6
Now we have a few more people on v6 I'd be interested to know if anyone else has seen issues or if I'm on my own?
Plusnet Staff - Lead Network Design/Delivery Engineer
5 REPLIES 5
18-12-2013 9:48 PM
Not running Vista anywhere any more (thankfully!), but I wonder if the machine is establishing a teredo tunnel after seeing the IPv6 traffic and thinking it needs to take charge.
Try disabling the teredo client http://www.mydigitallife.info/how-to-disable-tcpipv6-teredo-tunneling-in-vista/ and see if it still interferes?
18-12-2013 10:40 PM
No problems with my parents' Vista laptop but I do remember when I had two tunnels on two different computers, the vista would sometimes override the IPv6 route on the other machine. That was all when I was using the old NetGear (DG834Gv4) router but now with the TG582 giving out the addresses I've not seen this happen in a long while.
I do have the Teredo and latap (I think that's the right spelling but could be wrong) interfaces disabled in the Device Manager.
That's RPM to you!!
19-12-2013 12:34 AM
Currently running Vista on this laptop, no problems at all with IPv6, suspect something else is the 'problem'.
Running a relatively default setup, nothing significant disabled that runs by default.
Call me 'w23'
19-12-2013 6:13 AM
perhaps a stupid question but is the vista machine running in workstation or server mode ?
I seem to recall having problems with vista in that regard some years back (cant remember which version it was running though) but I'd changed the default from workstation to get a bit more oompf out of the thing but its been a few years since it got skipped so memories a bit foggy on the older os's
19-12-2013 6:48 AM
Quote from: w23 Currently running Vista on this laptop, no problems at all with IPv6, suspect something else is the 'problem'.
Fair enough, must be something with that particular laptop. Its not technically mine so said person can live with the world of IPv4 till they stump up the cash to move away from the old
