Speed HALFED again
- Trials
- IPv6 Trial
- Speed HALFED again
- « Previous
- 1
- 2
- Next »
Re: Speed HALFED again
09-04-2014 12:49 PM
There's a few IPv6 things I've asked them to look at (MTU/Packet Too Big Messages/Ping Spikes).
09-04-2014 1:28 PM
Quote from: chrcoluk andy you figured a way to get our asus routers to set a seperate ipv6 mtu to ipv4 mtu?
I haven't been through the thread so I might be taking that question out of context but it wouldn't make sense to have separate MTU values for IPv4 and IPv6 because they are carried over the same Layer 2 link and hence there can only be a single MTU value by definition.
09-04-2014 1:56 PM
09-04-2014 2:11 PM
I am wondering if there is a change somewhere else that might have caused this (our traffic passes through a lot of links before it even gets into PN's network).
Quote One answer I want is why when I set the ipv6 mtu on windows its not overiding the higher mtu on the router.
Interesting question. What if you try this http://ccie-in-3-months.blogspot.co.uk/2011/06/debugging-ipv6-mtu-issues-in-windows.html ?
Another thing:
Is anyone here on ADSL and have they tried playing around with a 1500 MTU for v6?
09-04-2014 3:05 PM
09-04-2014 3:47 PM
This should be easy to test with Wireshark.
09-04-2014 3:58 PM
09-04-2014 4:07 PM
ping -l 1445 2a02:68:1::4
The the first ping response should be:
Packet needs to be fragmented but DF set.
The rest of the pings should be normal (as they will be sent with MTU of 1492).
09-04-2014 4:15 PM
C:\Users\John>ping -6 -l 10000 2a02:68:1::4
Pinging 2a02:68:1::4 with 10000 bytes of data:
Request timed out.
Reply from 2a02:68:1::4: time=146ms
Reply from 2a02:68:1::4: time=148ms
Reply from 2a02:68:1::4: time=149ms
Ping statistics for 2a02:68:1::4:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 146ms, Maximum = 149ms, Average = 147ms
C:\Users\John>ping -6 -f -l 10000 2a02:68:1::4
The option -f is only supported for IPv4.
09-04-2014 4:50 PM
Quote from: AndyH I don't think they do - I've tried that MTU testing site the Plusnet gateways/core routers (other servers in a v6 traceroute) and they all show a max MTU value of 1500 for v6 traffic.
Another thing:
I expect this is related to traffic management configuration, so eg. pinging border routers doesnt really show anything. it only takes one intermediate device to not handle the larger mtu size to be incompatible or to forcefully resize the packets to break it. This may be only occuring on tcp traffic, which might explain why mtu discovery isnt working as well.
09-04-2014 6:20 PM
speedtested ok here.
http://ipv6-test.com/speedtest/
by ok I mean it matched the ipv4 result, both on that site didnt hit line speed.
I made a post on the tbb forums about the tbb speedtest issue (which also occurs when I am on mtu 1492).
- « Previous
- 1
- 2
- Next »
