Speed HALFED again
- Trials
- IPv6 Trial
- Speed HALFED again
Speed HALFED again
17-03-2014 4:49 PM
What has happened?
http://www.speedtest.net/my-result/3376933360
Re: Speed HALFED again
17-03-2014 4:58 PM
17-03-2014 5:03 PM
The last time this happened was an error by PN.
17-03-2014 6:57 PM
05-04-2014 12:33 PM
Result on ipv6:
Result on ipv4: my normal login:
This was just by changing my login details.
Now it MIGHT be gateway lottery again, but PN says this is a thing of the past
05-04-2014 12:36 PM
05-04-2014 12:44 PM
@Hairy McBiker Have you checked the current line speed on the portal and compared it with the IP Profile reported by the BT diagnostic test?
05-04-2014 12:49 PM
What is your MTU on your router if you run this command ip rt6advd iflist ?
Edit: It appears that speedtest.net is dual stacked but the test runs over v4 - so that should rule out a MTU problem
05-04-2014 2:52 PM
Estimated line speed:
Current line speed:
77.4 Mb
Not done a BT test as it seems fine on ipv4. (Which I am still on)
Currently:
I will drop this connection and re-login as ipv6
05-04-2014 2:58 PM
{Administrator}=>ip rt6advd iflist
Flags Legend: ttached anaged ther - Def. Rtr. Pref. ow / Medim / igh
Interface AdvInterval Lifetime Reachabl...
Retest using ipv6
So a little slower but not the major difference there was before, however the ping has more than doubled.
05-04-2014 3:15 PM
05-04-2014 3:25 PM
hairybiker@Duo:~$ ping bbc.co.uk
PING bbc.co.uk (212.58.244.18) 56(84) bytes of data.
64 bytes from fmt-vip72.telhc.bbc.co.uk (212.58.244.18): icmp_seq=1 ttl=55 time=19.5 ms
64 bytes from fmt-vip72.telhc.bbc.co.uk (212.58.244.18): icmp_seq=2 ttl=55 time=18.7 ms
64 bytes from fmt-vip72.telhc.bbc.co.uk (212.58.244.18): icmp_seq=3 ttl=55 time=19.0 ms
64 bytes from fmt-vip72.telhc.bbc.co.uk (212.58.244.18): icmp_seq=4 ttl=55 time=18.5 ms
64 bytes from fmt-vip72.telhc.bbc.co.uk (212.58.244.18): icmp_seq=5 ttl=55 time=19.0 ms
--- bbc.co.uk ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4001ms
rtt min/avg/max/mdev = 18.513/18.960/19.507/0.371 ms
hairybiker@Duo:~$ ping6 ipv6.bbc.co.uk
PING ipv6.bbc.co.uk(2001:4b10:bbc::2) 56 data bytes
still waiting for a reply, been over a minute now.
05-04-2014 3:50 PM
Try ipv6.thinkbroadband.com (2a02:68:1::4)
05-04-2014 3:53 PM
09-04-2014 12:12 PM
Quote from: AndyH Sorry...brain freeze...
andy you figured a way to get our asus routers to set a seperate ipv6 mtu to ipv4 mtu?
