IPv4 and IPv6 speed tests
jelv
Fixes: 10
Following some prompting TBB is setting up speed tests which will force IPv4 or IPv6 if you are dual stacked:
http://labs.thinkbroadband.com/flashipv4
http://ipv6.labs.thinkbroadband.com/flashipv6
See http://forums.thinkbroadband.com/newsite/t/4320873-ipv6-speedtest-update-version-0946.html
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
1 REPLY 1
rwaller
Re: IPv4 and IPv6 speed tests
Here's my results, looks normal to me, can't say I have had any problems so far,:
href="http://www.thinkbroadband.com/speedtest/results.html?id=139716497539248567941"><img alt="My Broadband Speed Test" src="http://www.thinkbroadband.com/speedtest/button/139716497539248567941-mini.png" /></a>
