Request to join the IPv6 Trial
kashmiri
Re: Request to join the IPv6 Trial
Excited to be so close to the launch!
Out of curiosity, whan translation mechanisms will the trial use? DS-Lite? If so, will the current static/public IPv4 addresses be preserved?
Fixes: 580
@kashmiri  the static ippv4 address is retained. Additionally you get an ipv6 /56 prefix via dhcpv6 over the pppoe link
archifishal
Reconfirming interest Smiley
Username: <removed>
Moderator's note:
Personal information removed from a public forum (to an area that staff can see).
trvrnrth
Hi Dave,
Could you add my account (<removed>) to the high touch trial too.
Thanks,
Trevor
Moderator's note:
404found
Hi Dave - my account is <removed>
With very many thanks!
Moderator's note:
rwhitton
Hi Dave,
Reconfirming my interest to take part in the trial. Username:<removed>
Many thanks
Moderator's note:
simon_lane
Hi Dave,
I'd be interested in joining the trial (<removed>). I have a static ip and a couple of subnets that would use ipv6.
Thanks!
Simon
Moderator's note:
Ripshod
I would definitely be interested it the trial, having moved here from vodafone.
Username is <removed>
Moderator's note:
ponteilla
Hi @dave,
I'm keen on being part of the trial. My PN username is <removed>
Thanks! 😊
Michaël
Moderator's note:
pseudonoise
I'm also interested in joining the trial - my username is <removed>
Many thanks,
James
Moderator's note:
BrummyGit
Hello
I would like to register my interest in joining the IPV6 trial please. It would be a huge benefit for my usage.
My plusnet username is<removed>
Steve
Moderator's note:
archifishal
@dave should I have heard something if I've been added to the IPv6 trial, or should it just have started working? 🙂
RealAleMadrid
Fixes: 68
@archifishal  You will be notified by @dave when additional customers are added to the trial.
Surprised that all these potential applicants are revealing their usernames on a public forum, not a good thing to do.🙄
Penny
Fixes: 9
Yes, had had the same thought - though not sure how else people are expected to identify the account to join the trial (often not the same as the PN forum username).
Sending it by PM is all very well (and practical) (and beneficial from a never-publicly-reveal-your-username type of perspective) but how else is @dave or @plusnettony or whoever, not going to be inundated with PMs which aren’t collectable together in quite the same sort of way as a forum thread allows.
I quite agree that people’s usernames being permanently visible here is not ideal, just not sure what the solution might be.
…. oh, actually, just had an idea.  If people post usernames elsewhere on these forums, there’s usually pretty soon afterwards a ‘note from moderator’ that says “personal info moved to an area that staff can see” (or some such).
So maybe that would work, here (?)
Posts can swiftly be flagged on the ‘report to moderator’ dropdown, so hopefully not cause extra work for Moderators in having to look for visible usernames every time there’s a new post here.
Trawling back through this whole thread might however become a tedious Moderator-task (and sorry, that clearly wasn’t intended) - but no, actually, the same would apply, people can just use RTM on any/every post here where the username is (still) visible.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Penny
Fixes: 9
@Penny wrote:   [03-07-2026 6:07 AM]
…. just had an idea.  If people post usernames elsewhere on these forums, there’s usually pretty soon afterwards a ‘note from moderator’ that says “personal info moved to an area that staff can see” (or some such).
 on ‎29-06-2026 12:56 PM - last edited on ‎03-07-2026 12:31 PM by Moderator @Baldrick1
... My plusnet username is<removed> ...
Moderator's note:
Many thanks to @Baldrick1 for having swiftly trawled through this entire thread and done that everywhere.
Brilliant.
