Public release
andrew_munro
Re: Public release
@dave  - another request to be considered for the trial (or the reserve list) please - I've got a dynamically-assigned IPv4.
Peter_JW
Re: Public release
Good afternoon @andrew_munro.
It may be after the Christmas period that this is picked up, but I can absolutely forward this on to Dave for consideration.
Please don't mention these in public, but are you happy for me to send over the details linked with your Community profile?
Peter
walterwhite
Re: Public release
@dave @Peter_JW
I have a Full Fibre 900 static ip connection. Using a glinet Flint2 Router (OpenWRT) and would love to be added to the trial when a space is available thank you 🙏
putney
Re: Public release
@dave  Yet another request to be considered for the reserve list, please - I have a static IPv4 address.
andrew_munro
Re: Public release
Hi @Peter_JW  ,
Yes, absolutely happy for any details in my profile to be sent to whomever if that's needed to be part of the trial - I understand there's been plenty of interest in this, so understand that it's likely to be after Christmas before there's any movement on this.
Thanks again,
Andrew
Peter_JW
Re: Public release
Thanks @andrew_munro, I'll forward your details over so @dave has these available in the new year, along with @walterwhite and @putney.
Based on his earlier messages it does seem it's closed right now, but I'll make sure your interest is kept on file should any new space on the trial open.
Peter
dave
Fixes: 20
Re: Public release
@dave wrote:
Thanks for the PMs everyone, my change is in the system for 10pm on 6th January.
@veremitz I've added you to the reserve list. I'm hoping to add some extra staff members next year so will be in touch then.
Change deployed for those on the pre-Christmas list. You should all now have IPv6. This should also fix both @druck and @Townman.
Anyone that's put your name for for the reserve list I'm going to add a few staff members in a few weeks so will post back nearer the time.
Dave Tomlinson
Plusnet Technology
druck
Re: Public release
Thanks Dave, all working again as of 22:17.
Stuper
Re: Public release
Working for me 👍. I run Unifi home network and configured it ahead of time. Just checked and I have working IPv6 address.
Thank You Dave for making this happen.
crgbt
Re: Public release
Thanks Dave - I can't seem to get it to work on my firewall with the settings I've used for IPv6 connectivity in the past (using the correct prefix size for Plusnet), but I'll start a separate thread for troubleshooting.
crgbt
Re: Public release
Sorry to bump this thread with another reply, but just to note that my IPv6 connectivity is now working after some troubleshooting and assistance from the community.
poweredbyveg
Re: Public release
Mine is working great with a Flint 2 router. Thanks
Fixes: 1,495
Re: Public release
Odd that the newly added ones aren't using IPv6 when accessing the forum though,  whereas the older ones are all showing IPv6.
Fixes: 246
Re: Public release
@dvorak
Do you profile me as old or new (in that I’ve been reconnected)?  Looking at my profile, it reports my most recent connection as IPv6.
Stuper
Re: Public release
I just worked out where to check. My ‘Ip address of last visit’ is currently IPv6. My device is currently on the home subnet where I enabled IPv6. If no issues I’ll enable on other subnets.
