Plusnet IPv6 Trial Next Phase
Kelly
Fixes: 9
Re: Plusnet IPv6 Trial Next Phase
If you've already got it up and running with IPv6, that's fine.
(it being the TG582)
Kelly Dorset
Ex-Plusnet Jobsbody
brueton
I had a TG582n  (with USB) working with IPv6 on the original trial with no problems, 10.2.0.B firmware, ADSL connection.
Also see http://community.plus.net/forum/index.php/topic,104512.0.html
Pete
chrcoluk
Please put me forward, but note my service is only just ordered so I dont have a active connection yet.
The router I will be using is ipv6 capable and I do actively use ipv6 (currently via tunnels) meaning I should be able to give good feedback.
Estragon
I'll give it a try if it's helpful to you.
ASUS RT-N66U, Fibre Unlimited.
Do you really mean v4 in "The v4 addresses will be <testusername>.plus.com"?
mrcoyote
Quite happy to give it a go here with an Asus RT-N66U.  It would be interesting to see whether the Vodafone Suresignal works with IPv6 as it's not great with FTTC on IPv4. Sad
idi
I would like to take part, have an ASA 5505 on Fibre Unlimited
MJN
Seasoned Pro
Fixes: 5
Quote from: Kelly
Yes, I'm currently using it as a 6in4 tunnel endpoint with HE.
deathtrap
What's the situation if you already have a static IPV4 address would this change too  or will the test accouunt be only for IPV6 ?
Another question as some of my software doesnt support IPv6 ie teamspeak3 server or client, will the IPv6 fall back to IPv4 for stuff like that Is it called dual stack ? As my router supports IPV6
These are the things that i would need to know before i could consider trying IPv6
sanyan
Hello,
I would be interested in the ipv6 trial.
Thanks.
max360
Which routers are compatible with IPv6?
mikecrawford71
Would like to volunteer for the trial. Running a Netgear WNDR4700 on my Fibre Unlimited account.
Currently have a HE Tunnel running on Debian.
Thanks,
Mike.
goldenfibre
Seasoned Pro
Fixes: 12
Edit: Post deleted. I just found out my router doesn't supportive IPv6
Netgear say my DGND3700v2 doesn't support IPv6
paulmh5
Quote from: deathtrap
Hi
Yes, you will get a different IPv4 address on the test account.  This will be from the dynamic pools.
Yes also.  Your software should be fine with dual stack, it will all depend on the server or service you are trying to connect to.  Things that are hosted on IPv6 should use that, everything else will be on IPv4.  You PC will continue to get its 192.168.1.x (assuming you use that range) address however it will also get an IPv6 one from the router.  If you have the IPv6 stack enabled chances are you will already have an fe80:xxxx address on your interface.
Plusnet Staff - Lead Network Design/Delivery Engineer
deathtrap
Count me out then, as the ipv4 needs to be a static for the ts3 server i host on my pc, plus it's set up with my domain , shame it couldn't of been trailed using my normal static IPV4 address
olisun
I have got a Asus RT-N66U and so please count me in..
