IPv6 connectivity issues today 8/12/13
- Trials
- IPv6 Trial
- IPv6 connectivity issues today 8/12/13
08-12-2013 4:15 PM
Just wanted to check in with others to see if you have some connectivity issues with some ipv6 sites. On one vista laptop I've been seeing some problems, one being with http://test-ipv6.com and some mirrors reporting no ipv6 connection (dns lookups in the test & red status in the mirror list). Most of the other mirrors report everything is ok so I don't think it could be a configuration error.
I should really test on another device but trying it on this iOS iPod isn't very accurate with the problem of 'happy eyeballs' (I think that's what it's called) switching between v4 & v6.
Re: IPv6 connectivity issues today 8/12/13
08-12-2013 4:26 PM
08-12-2013 4:47 PM
I built myself a new (Linux) router a couple of days ago, which includes the IPv6 tunnel endpoint, and have been testing it ever since.
The IPv6 connectivity has been faultless.
http://test-ipv6.com and http://www.thinkbroadband.com/ipv6/test-ipv6.html says it is all working without any issues.
Do you have a TBB ping graph on your IPv6 connection, to see if your tunnel is dropping ?
08-12-2013 4:51 PM
08-12-2013 6:15 PM
10-12-2013 9:34 PM
As soon as I change preferred server the problems go away. I've just recently submitted a support ticket to OpenDNS but not really sure I'll get much from them.
13-12-2013 1:48 AM
13-12-2013 7:59 AM
13-12-2013 8:01 AM
If you're not aware, they provide a free IPv6 tunnelbroker service which means you can get a real IPv6 connection as far as both your devices and the outside world are concerned. I've set up 2 tunnels, one at home, one at work - and it means I can directly access some of my home stuff (what I allow with firewall rules) without using a VPN or SSH tunnel.
The free training course is well worth doing, seems to be reasonably well structured to lead you through increasingly difficult steps, introducing new stuff at each step.
13-12-2013 9:45 AM
Quote from: purleigh No, we are using the Hurricane Electric 6in4 tunnel - https://www.tunnelbroker.net/
Speak for yourself I tunnel to a VPS 8). (Mostly because I wanted to see how hard it would be to eliminate the broker (and the NSA))
F9 ADSL customer since 2004
F9 FTTP customer since 2024
