international call blocking
- Home Phone
- Re: international call blocking
- « Previous
- 1
- 2
- Next »
22-09-2013 4:49 PM
I use C610H handsets, but I don't remember seeing dialing by SIP URL, although they can dial an IP4 address.
Message 16 of 19
(454 Views)
22-09-2013 7:17 PM
Quote from: purleigh I use C610H handsets, but I don't remember seeing dialing by SIP URL .....
I read this article a week or so ago, which is what inspired the thought that SIP URI dialling might be possible using the C610H handset.
Message 17 of 19
(454 Views)
22-09-2013 10:01 PM
I just followed what it says in the article, and sure enough that feature is as described.
Good find !. Thanks
Good find !. Thanks
Message 18 of 19
(454 Views)
23-09-2013 9:59 AM
Quote from: purleigh I just followed what it says in the article, and sure enough that feature is as described.
Glad you found the article useful, and thanks for confirming it works.
Do you have any other Gigaset handsets besides the C610H? If so, I'm curious as to which ones in addition to the ones described in the article might then gain the feature after the SIP URIs have been entered into the C610H (in particular I'm interested in my E49Hs, although I guess if you had one of those you would have mentioned it).
At least I now know it works with the N300-IP / C610H combination - I was already thinking of getting a C610H to try it with - so if I do manage to pick one up at a reasonable price on fleaBay it won't be a complete waste of time or money even if my E49H handsets don't gain the feature.
Edit:
Un-edit: Having just been looking on the Gigaset site, it seems I was right previously.
Message 19 of 19
(454 Views)
- « Previous
- 1
- 2
- Next »
- Home Phone
