disable 1571
- Home Phone
- Re: disable 1571
disable 1571
25-12-2021 8:53 PM
Want to disable 1571 voicemail but it is not ticked as one of my Call features. Can it be deactivated as I do not require it and never signed up for it. Thanks
Message 1 of 2
(987 Views)
1 REPLY 1
Re: disable 1571
27-12-2021 9:28 AM
Really sorry about that @JeanDavey
I've now placed the order to remove 1571 from the line, which should complete within the next hour or so. ![]()
