Where is PlusNet ‘Help & Support’?
TonyN
Re: Where is PlusNet ‘Help & Support’?
@mystreet1
Thanks! I’d forgotten about Duplicator. I did use it years ago to move a blog I’d set up and tested on my home PC with XAMPP to go live at PN.
My first ISP in the early 90s was enterprise.net in the Isle of Man which was the only one to offer local rate dialup at time. A lovely outfit which was taken over and eventually became part of PN.
TonyN
@MisterW
Better and better!
The MythicBeast wizard returns:
We are having trouble finding accurate data for the domain ‘ccgi.***.plus.com’.
But adds:
Get in touch with us via email and we will give you all the information you need to transfer your hosting.
Which earns them brownie points so far as I’m concerned!
TonyN
@markhawkin
I don't use it but Mythic Beasts seems to have the ability to host a Wordpress site.
I think you can do this on the (relatively cheap) webspace they sell rather than buying a Wordpress service from them.
It certainly looks that way to me and I’m going to invest in 100Gb of space so that I can dig around. Also thanks for the recommendation.
Fixes: 585
@TonyN
Yes, I assumed you would use your domain name in the wizard and it would (hopefully?) follow the redirect/forward from the DNS to the PN ccgi space , but maybe that is asking too much of it.
In reality most of the procedure is covered here https://www.mythic-beasts.com/support/hosting/hosted and here https://www.mythic-beasts.com/support/domains/transfer-no-downtime#sec-the-no-downtime-transfer-proc... .
Certainly when I transferred a website for a family member it was pretty simple, ftp everything from the existing host and ftp it to mythic. ISTR that its possible to test the website locally from the Mythic portal before switching DNS to make it live. I cant seem to find the details on the MB site though
Yours is obviously a bit more complicated due to Wordpress
Fixes: 118
@TonyN
Do let us know who wins - the bees or Openreach?
TonyN
@MisterW
Thanks for the prompt. When I put a domain name in instead of the server address MB found it and the option screen for transferring the domain came up fine.
I actually have three blogs at PN, one of which was under development and never went live. So next week I’ll try migrating that one to MB and see what happens before going for the ones that matter. WordPress seems to be a pretty popular option there.
To sum up, I’ve got the message about upgrading to full fibre before doing anything about the landline. After connection has been confirmed I must then transfer the landline number to a digital supplier within 30 days. I can trial it all with the PN router and then see if my TP Link is OK in which case I may need an adaptor for our cordless setup. Will probably do it all in October after a September holiday.
Using MB at least as a backup in case of problems with the stuff at PN is a no-brainer given the very moderate cost involved. And everything I see about them I like so I’ll probably go for full migration of the blogs.
I’ve received marvellous help and support in this thread with you leading the way and others making very helpful contributions. So is it possible to award more than one ‘Fix’? If not, which of your contributions should it be?
TonyN
@bmc
‘tis no laughing matter! They are in the roof-space just above the most obvious fixing point for an incoming cable and I love them dearly. With luck they will have started their winter slumber by October.
Tony
Fixes: 585
@TonyN
Its not , I'm afraid
Thanks, It doesnt really matter
Fixes: 480
Keep a very careful eye out for any messages from BT, especially when on holiday.
I would not be surprised if they wanted to move you off PSTN before October when their line rental cost increase to double what it was when you took out the contract. See https://www.openreach.com/news/openreach-announces-price-changes-to-encourage-digital-adoption-of-ne...
Fixes: 118
@TonyN
To followup on @Baldrick1 post you probably don't have until October to move to Full Fibre. Generally speaking BT probably will move you after a certain number of days if no response received. You need to control the timetable by placing your order for Full Fibre.
I believe once the FF order is accepted you can push the install date back a bit to give you just a little bit more time.
TonyN
@Baldrick1   and @bmc
Thanks for the useful and timely head-up on BTs possible deviousness. Will get on to them tomorrow to find out what they are up to.
Does anyone have any idea what the waiting time between ordering FF from PN and confirmation that it is up and running might be? Weeks? Months?
Fixes: 118
@TonyN
The install date depends on how busy local engineers are - perhaps a week or two. All things being equal the engineer will confirm Full Fibre is up and running on the day before they leave.
BT aren't being devious - they must get people off PSTN. They usually give people 30 days notice of the move to allow customers to make a chice of what to do.
Fixes: 480
@TonyN
Installation time depends on installer availability and if it's a 1 or 2 stage process. If you put the phone number in here: https://www.broadbandchecker.btwholesale.com/#/ADSL this will be revealed. You need to look at the information at the bottom of the table. If it's an underground installation that needs a new duct installing then this involves two different teams. Look out for KCI2.
If you want advice on interpreting the results then obscure the personal details and post them here.
TonyN
@bmc
Point taken, but the letter I have from BT gives the impression – certainly to someone not familiar with the ground – that the only way of preserving a landline number is to move to their very own FF service. A bit pushy I would say.
@baldrick
Another step forward – thanks.
As you tactfully anticipated, I have limited understanding of the output from that site, so an edited copy is attached and interpretation will be very much appreciated.
The download speed I get at the moment is about 9-10Mbps. As I understand it, even a move to PN's lowest 74Mbps package would provide a considerable increase. Or is that on a good day with wind behind us? I rarely download large files and do not use streaming except with iPlayer on a Sony Bravia television, so speed is probably less important to me than reliability. In any case I am paying a bit more for the ADSL package I have now.
Fixes: 480
@TonyN
White Full Fibre you will get the full speed, in your example 74 Mbps consistently FTTP doesn’t suffer from all the copper lengths and electrical interference vagaries suffered by broadband transmission l
You are in a fibre priority area so Full Fibre is the only service available to you. The new fibre to your property iwill be overhead to a telegraph pole. There is potentially a  problem such as trees in the way, is there any problem with the existing copper line? I have seen this recorded before when there have been no obstacles at all.
