Voicemail removal
dizzydevil
Voicemail removal
Hi how can I remove the plusnet voicemail service so I use my own answer machine at home. I've looked on my account settings and voicemail is not ticked. So my thinking is it should be inactive.
Darryl
7 REPLIES 7
Fixes: 246
Re: Voicemail removal
Hi Darryl,
A warm welcome to the forums.
There are some known issues wherein what the user portal reports and the configuration in BT's systems are not aligned.  Such things require a poke from a staffer.  Someone should pick this up later today.
adamwalker
Fixes: 223
Hi there Darryl, is this for a landline or a mobile service with us? Please feel free to send me a private message with either the username or mobile number as appropriate and I'll sort that out for you.
 Adam Walker
RealAleMadrid
Fixes: 68
@adamwalker  I don't think you can get mobile answer machines 😀 so it must be a landline.
dizzydevil
Hi, It is a home phone number.
dizzydevil
Adamwalker, I clicked on private message but it came up with a oops box with some text. so it looks like i cant send private messages yet.
Fixes: 246
After three posts you should be able to PM.
adamwalker
Fixes: 223
Hi Dizzydevil, you've made your third post so you should be able to message me now if you want to give it another try.
 Adam Walker
