VOIP Compatibility with Plusnet Fibre
Slunnyboy
Will a Phonely VOIP set up work with Plusnet Fibre? I would like to stay with Plusnet when I switch to Fibre but also want to keep my landline. Any suggestions warmly received
3 REPLIES 3
PhilipHeyes
All Star
Fixes: 12
Re: VOIP Compatibility with Plusnet Fibre
The key benefit of VoIP is it allows you to use any ISP and at any location.
The process for unbundling of the telephone number from the current PN service is the bit to pay full attention too.
Fajita
Yes, Phonely is a great option. My nan moved over to Phonely to keep her old BT landline she's had since forever.
As the other post mentions too, the benefits of digital landlines now is that you can use a landline with any broadband provider.
paul_blitz
Fixes: 4
And if you go on holiday you could take your VOIP phone with you! Kinda like you can take your Sky Stream!
