Strange landline problem
stephenwillo
I have just moved to Plusnet from TalkTalk and I'm finding that my cordless landline phone now indicates when a call is incoming but doesn't actually ring. The handset is not faulty since it works perfectly when connected to a line in a different property. Other corded and cordless phones work fine on my line.
I suspect that there is now insufficient voltage (gain) on my line to power the ringer on my existing handset.
Has anyone else had this problem? If so how was it resolved, if at all?
12 REPLIES 12
Legend
Fixes: 255
Re: Strange landline problem
@stephenwillo Welcome to the forums. Very strange, as cordless phones do not rely on the 'ringer' signal on your line - they have their own power,
Legend
Fixes: 255
Added for clarity
The other details you gave point to an issue with - probably - your base station/charging cradle.
stephenwillo
Thanks John. But it all works perfectly when connected identically at a different property ... ?
Legend
Fixes: 255
Does it ring if it is off the cradle when someone calls? If other phones in your house ring - how many have you got? - or at another property, it does point to the equipment, and not the fact that you have moved providers.
stephenwillo
Doesn't ring if out of the cradle. The other paired wireless units in the set don't ring either. Only one socket is in use in the house, so we're not looking at a REN problem.
Legend
Fixes: 255
If 'other corded and cordless phones work fine on my line', then something is wrong with that set of phones, most probably the base station - nothing to do with your provider.
stephenwillo
Openreach have identified it as an exchange issue. Plusnet have raised a fault.
Legend
Fixes: 255
I'm still confused - you have said 'other phones work OK' previously - if it is an exchange issue - discovered on a Saturday evening/Sunday morning, when AFAIK there is no OR support for such issues - we appear to be being given not the full story.
However, I hope you get it sorted.
stephenwillo
Found a very helpful Openreach engineer locally through a neighbourhood network who knows exactly what the problem is and was able to set the process in motion. Thanks for your help.
198kHz
Fixes: 41
@stephenwillo Intriguing. It would be interesting, and useful for future reference, if you could post back when you have details of the problem and its solution. Thanks.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
stephenwillo
The problem has now been resolved, and it was indeed at the exchange. I don't know the technical details but the OpenReach engineeer reassigned the line in some way. The handset is now working perfectly, as it did before the changeover to Plusnet. There was never a fault with the handset.
198kHz
Fixes: 41
Shame there's no further detail, but thanks for trying.
I'm just surmising - that maybe the change to Plusnet involved a shift to a different line card, and that card's ringing supply was not quite the full ticket. Maybe struggled on a longer line...?Huh
