Strange dial tone and flashing red light on phone
donmaico6
The dial tone surges up and down as if it is trying to tell me something.I dialled 1571 and was told a message had been moved ot 1572 which I also dialled and took the first option which is to divert to a list of unwanted callers.I thought that would end the matter but the light still flashes and the odd dialling tone persists.I have the phone number but am reluctant to phone it in case it is a  scam.I googled it and cant get any satisfactory information about it.Any suggestions?
7 REPLIES 7
EmilyD
Aspiring Hero
Fixes: 117
Re: Strange dial tone and flashing red light on phone
Hi @donmaic06,
Thank you for getting in touch. I've tested your line and it's not picking any problems up from this side.
It sounds like this may be a handset specific issue, for example the voicemail may have been stored on the handset rather than on our voicemail service which would explain why the light on the phone is flashing.
I'd recommend that you consult the manufacturer about this as they should be able to determine the cause of the problem. Alternatively, if you put the make and model of the handset on this thread there may be someone on the forum that owns the same one and is able to offer some advice on this.
 Emily D
Gel
Champion
Fixes: 29
donmaico6
the phone is a BT Decor 2500/.From  memory we didnt subscribe to BT (our previous provider) for call minder rather we use the phones own in built answering capability, the phones window is telling .  "MsGs dial 1571" so i did that and i them message I got was "you have no new 1572 messages". Now that "MsGs dial 1571" no longer appears on the window and the ;light has stopped flashing but the odd dialling noise continues
donmaico6
the red light is flashing again .Possibly a faulty phone?
donmaico6
i disconnected and reconnected the phone from the mains, Light has stopped flashing for awhile but returned and  the surging dialling tone continues.I checked both 1571 and 1572 and there are no messages in either. Whoever dialled used a vodafone mobile as it's 07776336330, a number i cannot trace
donmaico6
it seems i have somehow resolved the issue. Someone sent me text message tio my landline which i then deleted .The noise continued until I   set up a new greeting message /.Now all is well .Thanks anyway
Fixes: 1,652
Thanks for getting back to us, I'm glad to see this is sorted now.
Let us know if you need any further assistance.
