Plusnet Phone to Plusnet Phone
- Home Phone
- Plusnet Phone to Plusnet Phone
07-10-2013 12:39 PM
Re: Plusnet Phone to Plusnet Phone
07-10-2013 12:53 PM
Let me double check and get back to you.
07-10-2013 12:54 PM
07-10-2013 1:02 PM
Calls to Plusnet Support from a Plusnet phone service are free at all times.
07-10-2013 1:10 PM
So can/will this change to show a charge at some point?
I can't find anything in the T&Cs regarding this specifically for Plusnet to Plusnet calls.
07-10-2013 1:16 PM
07-10-2013 1:20 PM
Quote from: w23 That does happen but it's not supposed to.
So I assume they are normally chargeable after 60 minutes but sometimes you get lucky...
I had better just keep quiet then..
07-10-2013 1:37 PM
07-10-2013 1:43 PM
or, more importantly:
http://community.plus.net/forum/index.php/topic,108818.msg937636.html#msg937636
Quote from: Ben ...As such, if they are free at the moment they may not be free in the future
07-10-2013 1:48 PM
07-10-2013 3:13 PM
There have been some examples of customers not being charged when going over 60 minutes, this has been raised as problem 76863 and a fix is in active development so can be expected to be resolved in the next month or two (at a guess).
07-10-2013 3:19 PM
Quote from: Ben There have been some examples of customers not being charged when going over 60 minutes, this has been raised as problem 76863 and a fix is in active development so can be expected to be resolved in the next month or two (at a guess).
Ben, I would be quite happy if there isn't a fix... or maybe I should say my wife and daughter will be quite happy if no fix...
- Home Phone
