Phone fault
Champnet
Fixes: 21
Phone fault
For Info:
Just reported on the online fault system a problem with our home phone. No incoming or outgoing calls, no dial tone.
Broadband working as normal. Ran all suggested tests including an old phone pluged directly into the test socket.
3 REPLIES 3
SammyM
Fixes: 101
Re: Phone fault
Hiya @Champnet
I'm sorry you are experiencing issues with your phone, I can see it's been raised and we will keep you posted here.
 Sammy M - Sheffield Team
Champnet
Fixes: 21
Re: Phone fault
@SammyM  Thanks, didn’t really expect a Staff response today.
Champnet
Fixes: 21
Re: Phone fault
@SammyM Working again - thanks all....
