Phone currently useless
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Phone currently useless
28-02-2017 12:48 PM
My phone line is OK..Can't make outward calls (except to Plusnet).Inward calls are told I am engaged - for nearly 24 hours so far. Can't use mobile as only decent connection is from outdoors. Any helpful ideas please?
Fixed! Go to the fix.
28-02-2017 12:59 PM
Our tests aren't showing any issues.
Can you go through the steps here and let us know how you get on?
28-02-2017 2:15 PM
Hi, Thanks for your reply. No change I'm afraid. Can add that 1471 inwards is working - it tells me someone called about ten days ago.
I don't if it's relevant but it seems I may be getting inward calls from PN but not elsewhere.
28-02-2017 2:35 PM
28-02-2017 2:43 PM
Don't know why but phone suddenly back in working order. Sorry for waste of your time !
28-02-2017 3:10 PM
- Home Phone
