Phone currently useless
Greybeard0151
My phone line is OK..Can't make outward calls (except to Plusnet).Inward calls are told I am engaged - for nearly 24 hours so far. Can't use mobile as only decent connection is from outdoors. Any helpful ideas please?
5 REPLIES 5
MatthewWheeler
Fixes: 479
Re: Phone currently useless
Our tests aren't showing any issues.
Can you go through the steps here and let us know how you get on?
 Matthew Wheeler
Greybeard0151
Hi, Thanks for your reply.   No change I'm afraid.  Can add that 1471 inwards is working -  it tells me someone called about ten days ago.
I don't if it's relevant but it seems I may be getting inward calls from PN but not  elsewhere.
MatthewWheeler
Fixes: 479
If you can respond to the open question on your account we can get this looked into further.
 Matthew Wheeler
Greybeard0151
Don't know why but phone suddenly back in working order. Sorry for waste of your time !
MatthewWheeler
Fixes: 479
No problem glad to hear it's working.
 Matthew Wheeler
