Phone compatability
thePParchivist
Phone compatability
Prior to the copper switch-off I want to replace my phones. I have in mind the BT Advance with four handsets. Will this be compatible with VOIP on Plusnet?
8 REPLIES 8
Fixes: 388
Re: Phone compatability
@thePParchivist PN are not offering a VoIP service - you will need to arrange your own, so I would ask whoever you choose as your VoIP supplier the question.
thePParchivist
Thanks for that. I may have my terminology mixed up, but I understand I can plug my phone into the appropriate socket on the back of my PN router. That’s what I had in mind.
Fixes: 480
@thePParchivist
Once the service has gone digital there are two handset types that can be used:
1. Digital IP phone.
2, Your existing analogue phone via an Analogue Telephone Adaptor (ATA). This is the most popular option. Many routers come with a built in ATA. This will work fine with 4 handset DECT phones such as the BT range.
Whilst there is a socket on the Plusnet router, this does not function. As has been pointed out by @jab1 , Plusnet are not providing a digital phone service.
Fixes: 388
No, you can't, the PN Hubs VoIP capabilities are disabled.
thePParchivist
Thanks, Baldrick1, that was helpful.
greygit1
"Your existing analogue phone via an Analogue Telephone Adaptor (ATA). This is the most popular option. Many routers come with a built in ATA. This will work fine with 4 handset DECT phones such as the BT range."
Do you know how such a solution would work with 3 handset Panasonic model KX-TGC220E?
Just asking for a friend who doesn't want to needlessly throw away currently functioning hardware.
thePParchivist
Thanks, greygit1.
Sorry, I can't answer your query about Panasonic phones.
Fixes: 388
Simple - the base station plugs into the ATA.
