Old phone line
bm695238
Old phone line
Hi, after some advice. I switched to full fibre some time ago and haven't had a landline since. The old cable still comes to the house and thru the wall. Would like to use existing hole for something else. Can I pull old cable out myself, or do I need openreach to remove? Thanks
2 REPLIES 2
mystreet1
Seasoned Pro
Fixes: 7
Re: Old phone line
Official, OR own the line up to the master socket. If it was me, I would careful remove it and leave it tidy (so the wife was happy) on the outside. You should not climb up the pole to remove it.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
bm695238
Re: Old phone line
Cheers
