Old phone line
- Home Phone
- Old phone line
Old phone line
13-11-2025 8:52 PM - edited 13-11-2025 8:52 PM
Hi, after some advice. I switched to full fibre some time ago and haven't had a landline since. The old cable still comes to the house and thru the wall. Would like to use existing hole for something else. Can I pull old cable out myself, or do I need openreach to remove? Thanks
Message 1 of 3
(498 Views)
2 REPLIES 2
Re: Old phone line
13-11-2025 8:58 PM
Official, OR own the line up to the master socket. If it was me, I would careful remove it and leave it tidy (so the wife was happy) on the outside. You should not climb up the pole to remove it.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others.
Message 2 of 3
(491 Views)
Re: Old phone line
13-11-2025 9:09 PM
Cheers
Message 3 of 3
(477 Views)
