No dial tone
- Home Phone
- No dial tone
No dial tone
11-04-2011 1:45 PM
Hi there. On the 7th of April, I had received a text message from Plusnet that my Home Phone service was meant to be activated and this had not been the case.
When I installed my old phone, there was no dial tone and that the handset was completely silent. Convinced that the phone was at fault, I tested it and it was working alright.
What can Plusnet do for me?
Thanks for taking the time to read this
Ross.
Ross.
Message 1 of 5
(1,103 Views)
4 REPLIES 4
Re: No dial tone
11-04-2011 1:55 PM
Hi Ross,
The best thing to do would be to raise a fault - you can do this at http://faults.plus.net, or raise us a ticket at http://contactus.plus.net. The other option if you do have access to a working phone is to call us on 0845 1400200 and our support centre will make sure your fault is investigated.
Hope that helps,
Hope that helps,
Message 2 of 5
(544 Views)
Re: No dial tone
11-04-2011 1:56 PM
I'll do just that. Thanks for the response Matt
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Message 3 of 5
(544 Views)
Re: No dial tone
14-04-2011 8:31 PM
Just a brief update, I have phoned up about the problem and a check had been made on the line.
They have then forwarded this to BT and I managed to get an engineer to come over on Wednesday.
Message 4 of 5
(544 Views)
Re: No dial tone
15-04-2011 10:41 AM
HI russky89,
Has it been rectified now?
Jojo
Jojo
Message 5 of 5
(544 Views)
