No dial tone
osman
No dial tone
I have no dial tone.  Broadband works fine. I hardy use my landline, but today I made a call and left the number for a return call, which was very important, it rang once, then it went dead.  I called my number from a mobile, it rang ONCE only then it is dead again, so I cannot get incoming calls either.
4 REPLIES 4
Fixes: 244
Re: No dial tone
If you have no dial tone but internet is still limping along, then you are likely to have a dis leg fault - one side of the copper pair is disconnected.
You can use the phone fault link below to raise a phone service fault report.
LaurenB
Fixes: 131
Re: No dial tone
Hiya @osman, thanks for getting in touch. I am sorry for the issues being experienced with your service.
I have tested the line and this hasn't detected any faults, so we will need to look at sending an engineer.
if not already done so, I would advise to complete our troubleshooting here: https://www.plus.net/help/phone/phone-line-troubleshooting/ and if the issue persists, just get back to us on the ticket I've created here: https://www.plus.net/wizard/?p=view_question&id=220846997
If you give us a nudge on here once you have replied, we will pick that up for you.
 Lauren Barry
osman
Re: No dial tone
Hi Lauren
I went through the troubleshooting process and came to the conclusion that the fault was in the handset. I got a new one and the tone is back.  So for the time being everthing seems OK, no need for engineer. Thanks for the hints.
Regards
Fixes: 1,662
Re: No dial tone
Thanks for getting back to us @osman
I'm glad to see that your new handset's working fine now.
Let us know if you have further issues or there's anything else you'd need help with.
