1571 yet again.
Djay
1571 yet again.
I want 1571 voicemail disabled but it is not ticked as one of my Call features. Can you deactivate it as I do not require it and never signed up for it. Thanks
5 REPLIES 5
RichardB
Seasoned Champion
Fixes: 39
Re: 1571 yet again.
Hi
You can disable 1571 in the member centre.
https://community.plus.net/t5/Home-Phone/How-to-turn-OFF-1571/m-p/1223182#M18961
Try ticking and applying Voicemail, leave it 24 hours, then untick it.
Wait 24 hours and test.
Regards
Richard
Djay
Re: 1571 yet again.
Many thanks but, if it was that simple why did this happen ?
https://community.plus.net/t5/Home-Phone/disable-1571/td-p/1848236
Plus of course I would have no way of testing it.
I prefer to wait and get a member of Plusnet to permanent disable a facility that I neither asked for nor want.
adam945
Fixes: 113
Re: 1571 yet again.
Please accept our apologies for the inconvenience caused here @Djay
I've now placed the order to remove 1571 from your line, which should complete in a few hours, and will not be re-added unless you do so via your Member Centre.
 Adam
 Plusnet Help Team - Leeds
Djay
Re: 1571 yet again.
Adam
Many thanks for your help.
Problem solved
DJay
adam945
Fixes: 113
Re: 1571 yet again.
Great stuff @Djay, thanks a lot for letting me know. Please feel free to reach out if you have any further issues at all. Smiley
 Adam
