Landline or mobile problem?
brfoster365
Unable to call own landline from own mobile, message INVALID NUMBER
32 REPLIES 32
Fixes: 480
Re: Landline or mobile problem?
@brfoster365  Welcome to the forum.
For a start ring17070 from your landline and check that it is replying with the correct number.
brfoster365
Thankyou
I tried 17070 and my phone number is correct.
My mobile is with Sky which is O2. I can even call my landline from my Mobile.
Sky say its Plusnet, and Plusnet say its Sky mobile?
Bit of a dilemma as I was with NOW Broadband and have only had the problem since the changeover last week
Thanks for your help
Fixes: 480
@brfoster365
Your two posts conflict. Which way around do calls fail to connect? Whichever it is that can’t be called, do calls from other phones get through?
brfoster365
Just to clarify.
from my Sky Mobile to landline, message INVALID NUMBER.
From my landline to my Sky mobile, works OK
Fixes: 480
@brfoster365
Next questions, sorry for them all:
Can any-one else ring you on your landline number?
Am I correct in assuming that you are a new subscriber? If so, is it a new landline number allocated by Plusnet or has it been ported across from your last ISP? If so, who?
brfoster365
No its the same landline number.
Everyone else can call my landline from their mobile
brfoster365
Sorry last provider was NOW BROADBAND
Fixes: 480
@brfoster365
So you can make calls from your landline phone and everything else can call your landline phone. This sounds like a mobile problem to me.
You haven’t  by any chance confused things by trying to use WiFi calling and you haven’t configured it for your new hub?
adam945
Fixes: 113
Hey @brfoster365, thanks a lot for raising this with us. Sometimes, a number import doesn't complete across all Openreach systems, so I've just had a quick word with their Migrations Services Team and have been advised that there doesn't seem to be any issues, however they've raised the matter with Sky to see if there's anything that needs doing on their end.
I'll follow this up with you on Friday and will be in touch. Smiley
 Adam
 Plusnet Help Team - Leeds
brfoster365
Checked to make sure its not configured for calling using wifi.
I'm more convinced its a sky mobile problem.
Thanks for your suggestion
brfoster365
Thanks @adam945 very much for your help in this matter.
I have raised it with  Sky Mobile Community yesterday, nothing so far.
I'll post any replies I get from them.
adam945
Fixes: 113
Great stuff, thanks a lot for letting us know. Yeah I'm 99% sure it's an issue on Sky Mobile's side, but we'll see. I'll be contacting Migration Services again on Friday for a further update. Smiley
 Adam
Fixes: 251
There might be merit in identifying the range holder of the land line number. That may give Sky some clues over why their routing of the call from Sky mobile is going wrong.
It would be interesting to see if the number, when called from a Sky landline also misroutes.
brfoster365
Thanks @Townman,
If I call the Sky mobile mobile from my landline it does connect OK, and registers as the correct number.
I think this is what you mean ?
All very quiet from Sky Mobile community..
