Landline fault
MBplus
Landline fault
There is no dial tone on the landline.
I cannot dial out.
When this number is called, phone does not ring.
Broadband still functioning.
Tags (1)
13 REPLIES 13
Fixes: 374
Re: Landline fault
Tags (1)
MBplus
Re: Landline fault
Noticed the Plusnet Help Team have solved similar faults for others on this forum, so I’ll wait for them.
Thanks for your speedy reply.
Tags (1)
Fixes: 374
Re: Landline fault
Help Team response is slow on here at times, the bot is quicker.
Tags (1)
Fixes: 110
Re: Landline fault
@MBplus
If you're not in a hurry that's fine - they may or may not pick this up quickly.
Using the link given gets things moving immediately.
Tags (1)
MBplus
Re: Landline fault
Waiting for Plusnet Help Team as the report a problem link requires text, which I don’t have access to.
Thanks for your reply.
Tags (1)
Fixes: 374
Re: Landline fault
OK
Tags (1)
SammyM
Fixes: 101
Re: Landline fault
Hiya @MBplus
I'm sorry you are having issues with your phone, I have raised a fault here and we will keep you updated on the ticket.
 Sammy M - Sheffield Team
Tags (1)
MBplus
Re: Landline fault
Thanks Sammy, very much appreciated.
Tags (1)
SammyM
Fixes: 101
Re: Landline fault
Ah brill have a fab weekend!!
Tags (1)
MBplus
Re: Landline fault
Hi Sammy
Still no dial tone on the landline.
Could you please advise when it will be in operation.
Thanks.
Tags (1)
Fixes: 241
Re: Landline fault
Have you checked the ticket for an update?
MBplus
Re: Landline fault
Checked this morning and the question was on hold.
Now “released from hold and sent back to Faults”.
Awaiting Plusnet Support Team.
MBplus
Re: Landline fault
Everything working now!
Excellent BT engineer visited Sunday morning.
Fixed the fault at the junction box then checked inside our home to ensure both landline and broadband were fully operational.
Thank you to Plusnet Support Team who were very helpful and efficient.
Thanks also to everyone who replied here on the community  forum, really appreciate your efforts!
