Ex Directory
ReedRichards
Seasoned Pro
Fixes: 25
Ex Directory
On another thread it was stated:
Quote from: Oldjim
Plusnet automatically make new connections ex directory
I would be grateful for some clarification.  What do you mean by 'new connections'?  What do you do if you do not want to be ex directory?
10 REPLIES 10
Oldjim
Fixes: 63
Re: Ex Directory
It means that where the line is connected via Plusnet for the first time rather than via a migration (where I believe the situation from the previous supplier continues) it is ex directory
If you don't want to be ex directory you would need to advise Plusnet either at the time or indeed at any time after the line is connected
I haven't trawled back to where this was covered by Plusnet as it was a long time ago
GeordieMark
Re: Ex Directory
Sorry to hijack the thread but it seems relevant to this, does it cost to go ex directory?
Oldjim
Fixes: 63
Re: Ex Directory
no
GeordieMark
Re: Ex Directory
Thanks, think I'll request I'm removed Smiley
LukeS
Re: Ex Directory
Hi ReedRichards,
Usually, all new orders are placed ex-directory; that would be the default option. This should include, new installs, transfers and takeovers. Is there anything you'd like me to have a look at?
ReedRichards
Seasoned Pro
Fixes: 25
Re: Ex Directory
Hi Luke
I transferred my telephone service (from BT) to Plusnet at the end of June.  But I have no desire to be ex-directory so if Plusnet have made me ex-directory, can you revoke that please.
LukeS
Re: Ex Directory
I've placed an order to ADD you to the phone book. The request takes 48 hours, then it will take a bit longer to propagate through the various online directories and phone book.
ReedRichards
Seasoned Pro
Fixes: 25
Re: Ex Directory
Thanks very much Luke; I wasn't looking for instant results and 48 hours plus a bit longer is fine.
BRABUS
Re: Ex Directory
Can we look at this phone book online???
SpendLessTime
Aspiring Hero
Fixes: 86
Re: Ex Directory
