Engineer charges
FIXED- Subscribe to RSS Feed
- Home Phone
- Engineer charges
28-06-2017 4:24 PM
Fixed! Go to the fix.
Re: Engineer charges
28-06-2017 5:37 PM - edited 28-06-2017 5:51 PM
It can take a while for our suppliers to send the bill through with applicable engineer charges, however judging from the notes on the fault report I would say it seems pretty clear you shouldn't incur a charge on this.
I completed the ring ahead with the end customer and progressed to their premises and performed a line test. The test passed with some noise detected, with the fault located within the overhead network. There was a fault outside the end customer's curtilage and shown by general wear and tear and was fixed by re-terminating drop wire at DP/external block.
Edit: Typo corrected (Should changed to shouldn't)
28-06-2017 5:53 PM
@HarryB I hope you actually meant there should be no charge for this as a fault was found in the line external to the premises. I would be extremely annoyed if I was expected to pay for faults in BT's infrastructure.
28-06-2017 5:55 PM
29-06-2017 5:18 AM
29-06-2017 12:38 PM
Judging from the engineer notes, I'll be highly surprised if the visit was at all chargeable.
For the record, if an appointment is chargeable, we'd advise by email & text in advance of the fee being applied to an invoice.
Anoush.
