Crackly line
- Home Phone
- Crackly line
Crackly line
20-06-2014 4:27 PM
Hi Support, we have a intermittent issue with poor sound quality on calls. The voices can be heard but there is a loud crackle during th speech. The dial tone is clear and the crackle is only heard once the line rings out.
An example of this was today on an outgoing call at approx 1620 to an 01785 prefix number.
Quiet line test is clear.
Cheers, HB
Cheers, HB
Message 1 of 4
(741 Views)
3 REPLIES 3
Re: Crackly line
20-06-2014 4:56 PM
Hi happybunny,
Sorry to hear you're experiencing problems with your land line. I've created Ticket: 87392899 on your account which asks you to carry out further testing before we raise the fault to our suppliers.
Message 2 of 4
(288 Views)
Re: Crackly line
27-06-2014 4:16 PM
Hi Linn,
I've replied to the ticket. This thread http://community.plus.net/forum/index.php/topic,128491.0.html is similar to our issue.
Is it possible that the solution to this fault has fixed our fault?
Ta HB.
Ta HB.
Message 3 of 4
(288 Views)
Re: Crackly line
27-06-2014 4:40 PM
Hi happybunny,
Thanks for your time on the phone. As discussed, you are going to monitor the situation with your phone line and provide any updates that are applicable and we can then look into this. Fingers crossed the issue's gone away
Message 4 of 4
(288 Views)
