Can't change calling plan
mushroom_daddy
Although I no changes in progress (that I'm aware of), I am currently unable to make a change to my calling plan and receive the following message on my Phone control panel
An error has occurred
You cannot make any changes to your account while there is a phone order in progress.
Looking through the forums history, this seems to be a fairly common occurrence. I'd be grateful if my online account management pages could be reset so that I can make the desired changes to my calling plan.
4 REPLIES 4
Fixes: 1,662
Re: Can't change calling plan
Thanks for your post @mushroom_daddy
I can see this error's due to a couple of call features, which are showing in an awaiting activation state on your account.
I've placed an order with our suppliers to activate them, and you should see the error go away within a few hours.
Let me know if you have further issues though.
mushroom_daddy
Thanks @Gandalf (always helpful) this seems to have done the trick, and I have now removed/revised my call plan 😀
All I need to do now is hope 🤞that the displayed cost increase on the phone contract page doesn't actually translate into a concomitant hike in my overall broadband/phone package; as previously discussed in these forums – Changing Call Plan
Fixes: 1,662
Awesome, that's good to see and no problem, happy to help in any way I can. Cheesy
It shouldn't, but let me know if it does and I'll prod things back into shape. I believe our digital master @JonoH is seeing what he can do to make it clearer on the call plan change confirmation page that existing discounts won't be affected.
JonoH
Fixes: 157
I am indeed, I've raised this issue and we're in talks as to how best to display the correct information.
 Jono H
 Plusnet Community Manager
