Caller display
boannbird
Caller display
Is it that difficult for Plusnet to activate caller display? I checked *#234# where it wasn't available so I ticked the relevant box on 'call features' and waited....
Apparently now there's an error on my account so I can't do anything but call the 0800 number.
It worked with BT, same phone so what's the problem? It should be available by default.
8 REPLIES 8
boannbird
Re: Caller display
PS
I received two emails advising that 'my order' to remove 'voicemail' had been completed???????
SammyM
Fixes: 101
Re: Caller display
Hiya @boannbird
Thanks for getting in touch, sorry you are having issues with your call features and I can imagine how frustrating this can be.
We’re quite chocka right now, so it’s taking a little longer than I’d usually like to get back to customers and I'm sorry about that.
I have looked at the features and I have provided an update here, please get back to me if there is any errors so that I can fix this for you.
 Sammy M - Sheffield Team
boannbird
Re: Caller display
Thanks Sammy. I'm impressed at the speed Plusnet have dealt with both of my queries.
SammyM
Fixes: 101
Re: Caller display
It's my pleasure, have a fab week Smiley
charliejmonk
Re: Caller display
I can see that Plusnet have fixed the problem of Caller ID not working for lots of people. How do I get mine to be fixed?
adamwalker
Fixes: 223
Re: Caller display
Hi @charliejmonk, sorry that's not been working. I've raised an order to add that back in for you and it should take effect within the next 2 to 3 hours.
 Adam Walker
charliejmonk
Re: Caller display
Many thanks for the speedy reply.
adamwalker
Fixes: 223
Re: Caller display
No worries! Smiley
 Adam Walker
