Caller Protect issue
- Home Phone
- Caller Protect issue
24-10-2019 1:29 PM
Hi I am receiving spoof calls from an overseas provider threatening to cut off my service.
The number is 001443234957007
When I try to block the number via 1572 (last call) the system seems to die half way through quoting the number.
I am assuming the length of the number might be an issue.
Can you investigate this for me please?
Message 1 of 2
(495 Views)
1 REPLY 1
Re: Caller Protect issue
24-10-2019 2:00 PM
Hi @rabbit02
This *might* be the case - I'm not 100% sure how many digits can be entered when trying to blacklist numbers.
I'll try and get an answer to this asap and update the thread.
Thanks,
MoR
Message 2 of 2
(487 Views)
