Caller ID not working
MrsY
Since moving to Plusnet a few months ago my caller ID is not working.  It worked with my previous supplier.  Please can you help.  Thanks
3 REPLIES 3
2Donald
Re: Caller ID not working
Do you have it enabled in call features?
https://www.plus.net/member-centre/phone/call-features
Fixes: 577
@MrsY its not an uncommon issue. Its a mismatch between the Plusnet and Openreach systems, the PN system shows it as active but the OR system doesnt!. The fix is for PN to temporarily disable it and then reenable it, which gets the two systems in synch. You can either wait for a staff member to pick up this thread and arrange it, or you could call customer services who should be able to do it.
Fixes: 1,662
Hi @MrsY
I've added caller display and voicemail to our supplier systems, so that they match what's already showing as active on your account. These should start working within the next 24 hours.
Let me know if there are any issues.
