Caller ID not working
justiceaberdeen
i switch my phone line to plusnet on 20 / 3/17 plus caller display option,but the caller display not showing any number after the switched date, I check my plusnet phone panel it shows that active, it does show number before the switch date, please get it fix asap, thanks
4 REPLIES 4
MatthewWheeler
Fixes: 405
Re: Caller ID not working
Sorry to hear that.
Can you PM me your username so we can look into this?
 Matthew Wheeler
justiceaberdeen
[removed]
Moderator's note by Dick (Strat) Personal data removed from a public forum to a private area.
MatthewWheeler
Fixes: 405
I've placed a order to add it and it should be working soon.
Apologies for any inconvenience caused.
 Matthew Wheeler
justiceaberdeen
thanks  MatthewWheeler , fast respon, quick fix : )
