Caller ID not working
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Caller ID not working
30-09-2018 10:50 AM
Have tried #234# to no avail. what info is needed to correct this?
Fixed! Go to the fix.
01-10-2018 4:46 PM
Hi @wrinklie1,
To check if caller display is switched on it's * # 234 # if it's on you'll get the message "caller identity will be displayed". If it's not active you'll need to type * 234 #.
Could you try this again with the correct code?
02-10-2018 7:30 AM
HI
My dect phone doesn't appear to have the facility to enter spaces, so unable to try your suggestion
02-10-2018 8:22 AM
@JOLO must have got twitchy fingers - there are no spaces.
02-10-2018 11:56 AM - edited 02-10-2018 11:56 AM
@wrinklie1 Sorry, I added the spaces just to make it easier to identify the symbols/make it look a little cleaner. As @JayG has advised spaces aren't needed.
